跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
proximity sensor issue?
Proximity sensor works but it stays constantly on (screen turns off at calling without holding it to ear). I also checked it using code *#0*# everything else, is good proximity sensor displays 1 and screen vibrates and turns green. The ear piece area seems a bit loose. Can this be fixed without opening and replacing the proximity sensor or i need to replace this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Yes, check out the teardown.
Proximity sensor lies below the LCD, which is not minor surgery to remove.
Samsung Galaxy Note 4 Teardown
这个答案有帮助吗?
得分 0
添加一条评论
Hello, I have the same problem as yours. The proximity sensor is crazy.
During *#0*# test, for the proximity sensor, proximity sensor test displays 1 and screen vibrates constantly and always is green , exactly like you described. I have a samsung S7 Edge.
During calls, the phone screen turns off without holding it to ear! In WhatsApp calls, I can not even hang out because the screen freeze completly!
At first, I thought that it was related to the Roms, I tried a few, and even the Official from Samsung got the same issue.
So with the result from the sensor test, with *#0*#, I am (99%) sure that proximity sensor is guilty, and plan to change it. But how can it have been damaged?? kind of wierd.
How didyou resolved the problem?? did you changed the sensor??
Thx for any feed back, and recommandations.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Max 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,392
