跳转到主内容
模具型号A1707。于2017年6月上市,这台MacBook Pro的特征为配有Kaby Lake处理器,可升级至2.9GHz、可动态超频至3.9GHz四核英特尔酷睿i7处理器。
RAM Upgrade to more than 16Gb?
My new top of the line (maximum options MBPro) struggles more to cope with large files and edits in Lightroom than my old one.
Can the RAM be further increased to more than 16Gig?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 6
1条评论
Sadly, you're not the first to need more than 16 GB of RAM.
You might want to look at freeing up as much space on your internal SSD storage as you can as I'm sure you are running lean on free space. That way your system will be able to leverage it for virtual RAM. For storage of your work get a Thunderbolt external RAID drive (SSD if you can swing it).
完成的
添加一条评论
3个答案
已选择的解决方案
If you didn't buy the upgrade from Apple, no.
If Apple didn't make that option, no.
This machine has ZERO upgradeability. All upgrades must be purchased upfront and requires Apple providing the option in the first place.
这个答案有帮助吗?
得分 4
2条评论:
There was no option of more RAM available
完成的
The only option was to get the larger SSD storage which would have helped a bit.
完成的
添加一条评论
最有帮助的答案
Apple, in its infinite wisdom, is telling you that you don't need more RAM.
There is nothing wrong with your Macintosh.
Do not attempt to adjust the picture.
We are contolling the transmission .
If we wish to make it louder we will bring up the volume.
Is we wish to make it softer, we will tune it to a whisper.
We will control the horizontal.
We will control the vertical.
We can roll the image. etc., etc
We will control all you see and hear
https://www.youtube.com/watch?v=FCcdr4O-...
这个答案有帮助吗?
得分 5
2条评论:
@mayer - I love it:-}
完成的
添加一条评论
Well, I suppose if you were DosDude2 you could upgrade the memory, but for us mere mortals that don't do chip-level swaps and mods, we're out of luck. When I was getting a newer MBP for my daughter (she had a mid-2009) I researched which was that last fully-upgradable model, and got a mid-2012 for her on fleaBay (bought one w/o a disk and a minimal amount of memory, since I was upgrading those).
Now her machine is acting up, and I may have to get a newer one for her (would rather give her a ThinkPad with Linux, but she was using some Mac Apps)
@mayer is right. Apple products are products from the Outer Limits, certainly not from here on Earth.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gerrit Wyma 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 14,410
