跳转到主内容
Repair guides and support for all household mechanical fans including ceiling, box, tower, and stand fans.
Why can't I remove the blade cap from my Living Solutions stand fan?
I bought a Living Solutions stand fan. It has all the pieces, but it came with the blade cap firmly attached to the motor shaft, and I can't seem to get it off so that I can properly assemble the fan.
I have tried holding the motor shaft with a towel and with a rubber jar-lid remover so that I could try to screw off the blade cap, but it isn't moving no matter what I do!
Getting that off is all that is preventing assembly and I can't find any answers to this on the manufacturers page or find a customer service # to call.
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
12条评论
Would you give us a model number?
完成的
Thanks so much Philscbx!!!
Exactly the solution!
I would never have guessed that. EVERYTHING seems to have right hand threads.
Appreciated!!!!!!!!
完成的
You're very welcome,,
It's Fun when it works @!
完成的
Good gracious I was having the SAME issue until I found this post! 😂 So glad I didn’t break it by forcing it the opposite way for 20 minutes! Thank you guys so much. I’m still laughing at us!
完成的
I still don't get it.I've tried turning it to the left and nothing happens. I cannot get that off.Can someone please tell me what I'm doing wrong?
完成的
显示更多的7条评论
添加一条评论
4个答案
已选择的解决方案
Very Possible
Left Hand Threads.
This a mean trick used by Chrysler back in the 60's
For Lug nuts.
Good Luck
这个答案有帮助吗?
得分 3
添加一条评论
WOW! I had the same problem with a Comfort Zone oscillating fan and found this solution! Unbelievable! Left-hand threads! As soon as I switched to the left hand, the cap loosened like it was supposed to with great ease! What is the origin of this “trick” again? Was Chrysler the only one engaged in this trickery of mechanics? LOL Thanks for the support!
这个答案有帮助吗?
得分 1
2条评论:
Left hand thread means that the threat travels from the right to the left. From the top of the bolt or nut towards the shoulder. You don't physically have to change hands. Anti clockwise and not clockwise it stops things coming loose when they turn a specific direction. This is common with rotating items.
完成的
I had this same problem with my coolworks fan. Did exactly what you said. Spin the cap the opposite of what you would normally do when unscrewing anything but a fan assembly!
Thank you- I was about to take a hammer to it!
完成的
添加一条评论
This solution didn’t work for me. I’ve been trying for 2 hours with a break in between. I’m just going to return the fan to Lowes.
Did this not work for anyone?
这个答案有帮助吗?
得分 0
2条评论:
I’m frustrated returning fan to Lowe’s!
完成的
With model number shown, it maybe possible to get break down PDF to see
hidden details if problem still exists.
The store, if going there with the fan also have access to details on their computers. And will print out a copy.
Plus fixed on the spot.
Cheers
完成的
添加一条评论
Left Hand Threads on these appliances is common, just as washing machine agitators,
By grabbing cap nut and rotating it to the Right, while holding fan blade firm from turning.
Best of luck, and using a jar lid rubber gripping pad may provide extra grip.
It also may need a little heat from hair dryer to help break the bond.
Cheers
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
sadiepix 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 21
过去 30 天: 99
总计 24,896
