跳转到主内容
加入维修社区 - 创建账户
PS4 控制器型号 CUH-ZCT1。这款由索尼电脑娱乐公司于 2013 年 11 月发布的六轴 3.7 V 锂离子电池控制器维修起来并不复杂。(注:拆解指南不适用于此型号)
Why is my r2 button not working
My r2 button wont work right I have to press it really hard in Battle feild wont work in gta5 .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 10
2条评论
Chk the rubber on L buttons if ok!.
May need some control setting on call of duty. Shooting button response fast/slow
Hope this answer fix your prob.
完成的
I recently brought this PS4 controller on Amazon and now it’s not working on R2.
完成的
添加一条评论
4个答案
已选择的解决方案
Dont know of this helps or not but…. If your controllers get dropped regularly, like mine do…..take it apart, carefully clean the contacts of the conductive film and it's respective contacts on the circuit board. I use 90%+ isopropyl alcohol and a few Q-tips. Scrub, but carefully. Then use a clean cloth to buff the film contacts and the board contacts. Make sure everything aligns correctly when you screw the circuit board back down. Screw the circuit board back down and connect the battery and try it out. Unless your controller is physically broken, or the rubber pads are torn or crushed, this should fix your problem. Unless it was submerged in fluids, just smashed to !&&*, or a button was physically broken from being to rough….this had fixed every single one I've come across with a “shoulder buttons worked and now they don't “ scenario. It's almost always that film. It moves and that was a design flaw.
这个答案有帮助吗?
得分 3
3条评论:
Do you have any tips for the R2 activating when you're not pressing the trigger?
完成的
You could also switch the triggers to the bumpers (in the accessibility menu)if you dont want to break your controler or if you dont know how to work with the components (like me)
完成的
Mind does work but in assassin's Creed 4 he will only jog so it thinks it's not being pushed down all the way
完成的
添加一条评论
最有帮助的答案
Could be a number of issues: the plunger on the inside of the button could be cracked, the button switch could be loose, or there could be dirt or damage to the button switch. Gonna have to open it up and have a look.
DualShock 4 按键更换
这个答案有帮助吗?
得分 4
添加一条评论
Here’s a simple solution to fix buttons that don’t seem to be working. It does requiring taking the controller apart.
https://www.youtube.com/watch?v=Lx3La8a1...
这个答案有帮助吗?
得分 1
1条评论:
Dude I logged in just to say thanks lol this link helped me big time. Just managed to fix my controller
完成的
添加一条评论
How do i fix my r2 button to shoot without pulling it apart
这个答案有帮助吗?
得分 0
3条评论:
Blow air into it with ur mouth worked for me
完成的
Did not worked for me lol ear me out if there is another solution to repair it whitout pulling it apart
完成的
Coby Roberds that actually worked, thank you
完成的
添加一条评论
添加你的答案
Lane Bauer 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 137
过去 30 天: 632
总计 165,795
