跳转到主内容
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
Can start in Safe Boot only
iMac Intel 27" Late 2009
Hello there,
My iMac is having serious freezing issues.
When I was watching a YouTube video, my iMac completely froze. I could only move the cursor. I had to shut it down using the power button. It froze a few more times before it started freezing when starting. It would freeze at the Apple logo and the progress bar.
I tried resetting the NVRAM. Started in Safe Boot to close all the programs that hadn't closed properly.
Next I reinstalled macOS Sierra from recovery. That didn't work.
Then I took it to the apple Genius Bar where they did some heath checks and it passed all of them. Next they reinstalled a fresh copy of macOS directly from their servers. It started up fine. I set up an account whilst there and I brought it home.
I tried customizing my Mac and it started freezing again.
Before taking it to Genius Bar, I even swapped the rams to see if they corrupt. But they weren't. I still had the same problem with the other rams.
I don't know what is wrong with this machine. 2.5 years ago I also had the logic board relaxed through Apple.
I can start the Mac in Safe Boot only.
Please help!
Cheers!
Abhishek
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
What virus protection program are you using? How many programs of the (Clean my Mac, MacKeeper, Fix my Mac) type have you downloaded and installed?
完成的
添加一条评论
1个答案
最有帮助的答案
When you reinstalled Sierra from the recovery partition, I'm betting that you did NOT do a clean install but instead just replaced the in-place operating system. That would be why your installation failed but Apple's succeeded.
The key -- obviously, I think -- is the "customizing" you're doing to your Mac. Something that you're doing or installing is creating an OS-level problem.
Clean-reinstall the OS and use it for a day or two like that. Don't add any software or anything like that. If it's still working, then add ONE thing and use it for a day or two. Repeat until your computer fails. The last thing you installed is the culprit.
这个答案有帮助吗?
得分 1
3条评论:
I agree with Steve. It ran fine until you started customizing. Just exact what did you do to customize it?
完成的
By customizing I mean adjusting the size of the dock. Enabling right click on the mouse. Increasing the track speed of the mouse. Adding sound to the menu bar. Changing the time to 24 hour format. Just basic things.
If I were to install any apps they would be chrome, VPN, daisy disk, etc. nothing very powerful.
Apple did a clean reinstall of the OS at the store from their servers. I think it's the ram slot or the logic board that is failing. When the computer freezes, the cursor still moves and the computer goes to sleep and all. I can even wake it up by hitting a key on the keyboard or by clicking the mouse.
Don't know what the issue is. This is really strange.
完成的
If a clean/untouched OS is able to run without crashing, it's not the logic board.
It MIGHT be memory-related. If your memory module has a defect in an area of high memory, it wouldn't affect the performance of the computer until/unless the OS went to access that memory. If it did so by putting a critical bit of data in that bad spot, it could crash the system. With a clean OS install you may not be "touching" that bad spot, but once you start using the system the OS's memory footprint would expand a bit and perhaps touch that bad spot.
If you have two memory modules installed, remove one and try the system. If the problem persists, remove the second one and put the first one in the slot where the second one was and try the system again. If the problem STILL persists, try another memory module. If the problem goes away during any of the swaps, the last module you removed is the culprit.
完成的
添加一条评论
添加你的答案
Abhishek 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 103
