跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
Optical bay hard drive won't mount before login, anyone?
I bought an optical bay sata hard disk adapter and installed a 640gb samsung drive in it. I have an MCE SSD I use for all my OS partitions and the optical bay drive for all my media (formatted exFAT since it's natively supported by later OS X versions and windows 7)
I have my OS X home folder on the media drive and for some reason I experience this odd 'bug' where the drive won't auto mount before I login. I get to the login for my user account, enter my password and then I'm greeted by a very long scrolling progress bar... when I finally get to a desktop it is a default account and osx informs me it could not find my home folder...
I have started having the startup issues again... I then get disk utility out and can see the Media HD (drive where my home folder is located) is grayed out so I manually mount the drive, no issues, reboot, login, loads into my user account as normal... of course if I restart or shut down again I have to start the whole process over again :(
repairing the drive or os x partitions doesn't seem to work nor does repairs, I had used an fstab file but have since removed it to keep that variable out of the equation... though it never made any modifications to the boot or media drives (I used it to auto hide repair partitions on an external drive) I attempted to explicitly state in fstab to automount the partition but that had no effect on the problem and from what i've read about fstab in os x it is only accessed after login anyway.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
I would reformat the exFat drive to Mac OS Extended (journaled). Although your Mac will read and write to the drive, it was not meant to run off it. Thats why they make things like BootCamp. I think all your problems will be gone if you do this.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
matthewjcoppola 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 1,444
