跳转到主内容
加入维修社区 - 创建账户
在2015年3月发布,于2015年4月10日开放购买,Galaxy S6 Edge是Samsung最新的旗舰智能手机的曲面屏幕版。
S6e still doesn't seem to work after 3 days in rice.
I've googled what I should do and rice seems to always be the go to, so I've done that for 3 days and when I plug the charger in it loads fast to 100% then I try to turn it on and it gets stuck looping the Samsung logo but never opens the start menu. Any suggestions? Should I keep charging it? Or will that further damage my phone?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
I take it that it got liquid damage. It hasn't been opened or dried out. Is it synced to a PC or a Mac? Rice as a desiccant is an old wives tale.
完成的
Sorry, yes it was dropped in water :( and it hasn't been opened. it was synced to my PC.
完成的
I'm going to let one of the younger phone pros help you on this one, @theimedic @refectio. OK boys, do your stuff ;-)
完成的
Thank you, I can just imagine how many similar questions you have all answered and I hope this isn't like nails on a chalkboard to you lol. I saw a similar request but the questioner never followed up with his/her results. Thanks in advance :)
完成的
添加一条评论
1个答案
已选择的解决方案
Get you phone out of the Rice and deal with it properly . Shut the phone off and we'll start by tearing the phone down . This guide will help 三星盖乐世S6 Edge拆解 . Clean every connection with a soft toothbrush. As well clean the logic board; use a 99% isopropyl alcohol for all cleaning.Scrub all connections and the entire inside of the phone . Dont use the alcohol on the screen Now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several days moving it from time to time to get the max effect from the desiccant. Use a blow dryer on a low heat setting to dry the rest of the phone. Only use a hair dryer once you have cleaned the phone completely with the alcohol. Do not attempt to dry the phone if it’s still wet with water with the blow dryer as this only spreads the water. Replace the battery with a new one considers the old ones done. Clean again with isopropyl alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone it’s time to power it on. Hold your breath and hope for the best
这个答案有帮助吗?
得分 4
11条评论:
If by change you have access to a ultrasonic bath you would do well to clean the parts in that using distilled water and a cleaning solution
完成的
Beat me to it :>). Good answer!
完成的
Sorry @refectio I was in the midst of my answer when @mayer called for your attention didn't mean to step on toes
完成的
@jimfixer google says that is the same as rubbing alcohol correct? And by scrub, does wiping with a q-tip count as scrubbing?
完成的
some use q-tips I prefer toot brush , I actually use an ultrasonic bath but used toothbrushes in the past . As for rubbing alcohol as long as the alcohol content is above 90% then yes its fine but if its a cheaper lesser % then this can cause as much damage as the water . If you don't have access to the ip alcohol or a pure form of alcohol then completely distilled water will work but you will need to clean it more thoroughly as the distilled water becomes mineralized as it cleans and its the minerals in the water that actually causes the damage when the phone dries out . these mineral will cause corrosion to start and the corrosion ends up shorting out the phone
完成的
显示更多的6条评论
添加一条评论
添加你的答案
S judge 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 8
总计 185
