跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Just won't restart without strange screen and then shuts down.
My MacBook Pro refuses to boot up cleanly after crashing.
It says your computer has restarted because of a problem, press any key or wait a few seconds to continue starting up.
Then it just shows the Apple logo and stays blank. Then the whole screen is occasionally covered in rainbow noise and it shuts down.
Please I need help
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Did you get your system wet or bang it?
Can you tell us a bit more here when the system restarts are you in the middle of a game or other taxing app (system is a bit warm/hot)?
If you let the system sit awhile will it start up then?
完成的
添加一条评论
1个答案
已选择的解决方案
First see if you can start it in recovery mode. When booting hold down the option key the select the repair partition if it comes up. Next run Disk Utilities on the drive.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Chioma Goodness 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 148
