跳转到主内容
加入维修社区 - 创建账户
1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
Power won't charge battery issue
#1
I have a 13" 2012 MacBook Air. When I plug in the power cable the LED does not light and the battery does not charge. However, if I remove the battery connection from the logic board, the LED lights. When I re attach the battery to the logic board it charges. If I remove the power cable and reattach it, while its charging the LED will not light and the battery will not charge. I've tried changing power cables (with a brand new charge and the problem remains. I've tried to reset the PRAM AND SMC several times and the issue remains. I'm at point where I either try replacing the battery or the logic board.
My thoughts, since the power cord does charge the batteries, the it cannot be a connection issue. Also the USB and headphones work without issue. I have a feeling the issue is simple but I'm not sure. Replacing the battery is cheap but the logic board, is cumbersome as well as $$$.
Any ideas? I appreciate the feedback.
Update (08/26/2017)
For the record, I let it charge to 100% then I reattached the battery cable. CoconutBattery states that the power is not connected, even though it is...
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
The fix was replacing the logic board. I brought it to the Apple Store where we diagnosed the issue. I purchased a logic board online and boom! It works! YES!
这个答案有帮助吗?
得分 0
添加一条评论
最有帮助的答案
Let's get a better look at what is going on. Please download, run and post your results with Coconut Battery.
http://www.coconut-flavour.com/coconutba...
UPDATE
Thanks for the battery info. It looks OK.
Has anything happened to the machine, a spill or a drop? Are you the original owner?
这个答案有帮助吗?
得分 1
1条评论:
MacBookAir5,2
Manufacture date: 2013-04-15
Current Charge 3939 mAh
Full Charge Capacity 5638 mAh
Design Capacity 6700 mAh
Manuafacture data 2013-03-22
Cycle Count 606
macOS Battery status Good
Battery temp 31.9 C
Charging with 23.83 Watts
Power adapter Connected.
Battery Man. Simple
Age 1618 days
Battery Failure None
Now, I'm charging the battery now. But I had to go through the process above to do it.
完成的
添加一条评论
添加你的答案
Mark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,644
