跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
Home Flex Cable Replacement
I was fixing the batter (I have battery issues) when I accidentally bumped my phone off the counter and it tore (completely separated) the home button flex cable. I ordered a new home flex cable, but after doing some research- will I need to
A.) buy a new home button as well?
B.) will I lose my touch id function even if i keep the home button?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
hi Taylor, you must use it with your home button otherwise you will lose touch id function.
goodluck
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
If you tore this cable, you are okay with the touch id
But if you tore this cable, then you will need to buy a replacement button and you will lose touch ID but home button function will work
这个答案有帮助吗?
得分 5
4条评论:
Great! I tore the flex cable up at the top, like the first image you've shown. I'll just be crossing my fingers until my flex cable gets here :)
完成的
You are fine then, just use the original home button:)
完成的
Taylor, you accepted the wrong answer ;-)
完成的
@mayer at least she got an answer she is happy with ;-)
完成的
添加一条评论
添加你的答案
Taylor Fuller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 129
