跳转到主内容
更大尺寸的 Nintendo DSi,北美市场于2010年3月开售。大多数维修只需要一个螺丝刀和塑料撬具即可完成。
Why won't my DSI XL turn on
My DS is fully charged and the last time I was on it it worked fine. Then I try to get on it today and when I turn it on the bottom screen will light up for barely a second. I know it's not because of the charging the orange light is lit up because I'm charging it right now. It's not because I dropped it because I haven't. Is not because any water has spilled on it because it hasn't even been near food or water it has literally been sitting on my desk for maybe a month now. I tried to turn it on with it charging and without it charging so I know it's not water damage, charging or the battery is shot. If someone can tell me what is wrong and how to fix it then I'll be the happiest person in the world
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi.
Try booting the console with the memory card and game cart removed.
If that does not work, remove the battery, flip the power switch on, then put the battery back in.
If this does not work, you might have a motherboard brick on your hands.
这个答案有帮助吗?
得分 2
2条评论:
how do you boot the console with a memory card and I did the battery thing
完成的
The memory card slot is behind the latch next to the stylus. Remove it and power on the console.
完成的
添加一条评论
添加你的答案
Beth 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 11
总计 2,580
