跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
How to fix the blinking question mark folder?
I have this blinking question mark folder on my screen.
I looked for the solutions and I found that it's not the hard drive problem, but the cable that connects the hard drive...
So I tried to order a new cable and replace it, but I just found that MacBook Air 2013 (A1446) does not have the connecting cable... ;(
It has a solid(?) or fixed SSD adapter instead.
So is there any way that I can replace the adapter (?) of SSD? (not SSD board itself)
Or... Is there any other solution?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
A little bit of knowledge can be dangerous. The likelihood of this being a bad SSD is low and there is no cable the SSD connection is integrated into the logic board. Most likely is that you have a corrupted system folder. Reboot the machine holding down the option key and select the repair partition. Run Disk Utilities on the drive and see if you can repair it. That failing you can then try a reinstall of the system.
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
The blinking question mark usually happens with faulty drive in this series.
Inspect your SSD connector to logic board for corrosion or damage. Most likely your SSD drive is gone.
You'll need to test it with an Apple SSD to USB adapter and connect it another Mac, or buy new SSD.
MacBook Air 2013 SSD's are PCIe based. Proprietary to Apple as explained here:
EveryMac - MacBook Air Q&A
在MacBook Air 13''2013年中期上更换固态硬盘
这个答案有帮助吗?
得分 3
2条评论:
OWC offers the required SSD and the carrier to hold it: SSD Flash Storage Options For MacBook Air 13" 2013 - 2017
完成的
Thanks a lot for the answer
完成的
添加一条评论
添加你的答案
정찬경 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 8
总计 7,608
