跳转到主内容
加入维修社区 - 创建账户
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
iPhone won't turn on black for a full month
I bought an iPhone and I didn't have it for at least 3 months one day it just turned black and it was unresponsive I tried taking it to multiple repair stores they are all swying can't fix it sorry.Someone help me fast I don't wanna go to the Apple Store and wast $300 bucks for a repair.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Does it turn on at all?
完成的
Nope it has not
完成的
I mean I only had I thought for 3 months and if you have any more tips please give more
完成的
添加一条评论
1个答案
已选择的解决方案
You need to determine if the phone is truly dead or just not displaying an image. The iPhone 6S is known to have backlight circuit issues. I don't understand what you mean when you say you didn't have it for 3 months. Also, what did the repair shops try. The more information you give us the better.
Here's what I would try for now:
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Disconnect the Lightning connector and then re-connect it.
  • Does an iTunes enabled computer recognize your phone?
  • If it does then shine a bright flashlight on the screen. Do you see a dim image?
If you have access to a USB Ammeter, you could use that to determine if the phone is really drawing current when it's charging. You could have a dead battery. Apple has a recall program for the iPhone 6S experiencing unexpected shutdowns. I would check out the site to see if your phone is eligible for a free replacement.
If you see a dim image, then you probably have a defective backlight circuit on the logic board. If you don't see an image, then you most likely have a completely dead logic board (or battery, see above). Anything logic board related will require a micro-soldering repair and is not DIY.
这个答案有帮助吗?
得分 4
12条评论:
I have tried that
完成的
Anything else I believe it's the logic board
完成的
@leylatocool if you tried all of the above and if your ammeter shows it is drawing current, then the only thing left to do is to go to Apple and have them replace the battery under the recall program.
完成的
Ok but I only tired having it on charger but not apple charger a different brand and I also tried itunes
完成的
@leylatocool you stated above that you tried all that. I suggest that you follow the instructions given by @refectio and not just say you have. We cannot help you if you do not follow what is suggested. So you need to do as suggested to see if this is the problem. Otherwise take it to Apple.
完成的
显示更多的7条评论
添加一条评论
添加你的答案
Leyla 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 139
