跳转到主内容
加入维修社区 - 创建账户
Nintendo DS 的后继机种 Nintendo DS Lite 于2006年发布。这款设备的拆解和维修十分简单。
Replace DS Lite CPU
What tools do you need for replacing the CPU on a DS Lite, and wich ways can be used to pry off the CPU ? I'v got 3 motherboards with (blackscreen) bootup seems their CPU aint good. I'v opened them by desoldering the 4 slot1 contacts and bend it up a little. After pushing it hard back into place 1 board began to works again.
For the other 2 i can't say this. Maybe the CPU is toasted ? I cant get them to work (yet)
Please Advice! wich ways is the best for repairing the CPU and what tools do you need?
Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi dbnijmegen, sometimes it is good to have a schematics of the board, and check if there is voltage supplying to the CPU.
e.g. certain power management chip, etc.
the cpu i believe is a BGA, which replacement can be difficult without proper tools and skills.
you need a rework station, e.g. hot air, bga rework station infrared to remove it.
and resoldering ... those bga balls need to be in place.
这个答案有帮助吗?
得分 1
1条评论:
Hello Augustine, Thanks for your reply. By testing out all problems i figured out it must be a bad CPU Since i got 1 back to work. i figure, would there be a way without this station. ex. by a heatblower ? one cpu only needed a little more pressure on it. i think the same problem is for the 2 other motherboards, but i cant get them to work by supply some extra pressure to it.
So either 1, i need to find another possible way to make sure the cpu is attached proper.
or 2: i need to replace whole CPU cause its toasted. (i guess, no experience YET!)
Where can u buy this station, what does i costs, and also i need something to pull it off and put it back on it ? How you soldier it back on ? also with the BGA station?
Thanks! Dennis
完成的
添加一条评论
添加你的答案
dbnijmegen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 817
