跳转到主内容
Released March 2016, 7.0" Galaxy Tablet by Samsung.
there is a X mark on battery icon
I dont know if its the charger or the pin in the tablet that has something wrong. When i plug the charger there is a red X mark on the battery and it wont charge. I have to power off the device in order to charge it but I need to stay the evice open because i need things in here. Help how do i fix it?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
3个答案
已选择的解决方案
If you are charging it via your computer, switch to a charger.
这个答案有帮助吗?
得分 3
1条评论:
No, im charging it with its charger. But there still an X mark
完成的
添加一条评论
Usually this means battery is bad or near end lift. Try to use the device till battery is completely drained then full charge again. Repeat this step for 2 to 3 times and if it still happen. You need a new battery.
这个答案有帮助吗?
得分 0
1条评论:
I’ve got a 51 located on the battery icon. What does that mean
完成的
添加一条评论
Mine does the same thing but I just got a new battery so I know it’s not a battery problem.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
aju shee 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 13,765
