跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
When home button is clicked Once it does 6-7 rapid clicks
Hello I have a customer with an iPhone 7. I replaced the screen and the home button is odd. I click it once and the home button gives me about 6-7 rapid clicks. Is it the home button pressure sensor? How can I fix this.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hey!
Try to disconnect the Home-Botton connector from the flex cable behind the LCD assembly, remove the Button completely and resest all parts again. Then test it again.
这个答案有帮助吗?
得分 0
2条评论:
Tried that still having same issue.
完成的
Okay, in this case - if you are really sure all is sitting in place and is connected correctly - it could be possible the flex cable or button itself was killed. I rememvered the button and its board sticks very hard at the back of the LCD assembly and needs to remove carefully. Maybe you detect any damages at the board or cable?
And I think you should try another home button-flex.
完成的
添加一条评论
添加你的答案
Hunter Kegher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 674
