跳转到主内容
iPhone 3G 的改进版本,具有更快的处理速度。该设备的维修与 3G 类似,需要简单的螺丝刀和撬具。型号 A1303/8GB、16GB 或 32GB 容量/黑色或白色塑料后盖。
It doesnt turn on, or do anything after fall...
i had My girlfriends iphone on my pocket and i fall having it in my pocket...the iphone seemed like nothing happened, no scratches, no broken screen, no nothing...but i didnt turned on nor wanted to receive any charge. Currently is with some technicians but the dont find what it has. They told me that everything inside seemed perfectly normal, that they tested the screen and the touch and it worked, and they also tested with a new power supply and it didnt turned on neither. the iphone is supposed to be in warranty but where she lives is a little warm place, the dock sensor was a little pink. So I was wandering what could be the problem or if i can change the sensor? ( because all sensors even the ones inside and the headphones sensors where white). I Hope that you guys can help me...my girlfriend really needs her iphone cuz she used it as a modem.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
My iphone 3gs has done the exact same thing, will not power on, light up or anything after being dropped from about 2 feet. I had it in a otter case. There must be a common problem for these phones to do this with no apparent physical damage.
I someone has had a similar problem, please post.
I think I am going to buy a different brand next time!!!
Later, Dave
完成的
Is it recognized in itunes when plugged into the computer?
When you switch the vibrate switch back and forth, does it vibrate?
完成的
添加一条评论
3个答案
已选择的解决方案
Did your "technicians" just swap parts over to test screens etc? I think they need to test the dock connector or swap your board into a known working phone. Battery prongs can get flattened in drop, easy fix. Checking with magnifier can help but not always
这个答案有帮助吗?
得分 2
添加一条评论
Look at the logic board under a magnifying glass for any marks. Also try doing a hard reset. (Hold Power + Home Button) Does the computer recognize that the iPhone is plugged in?
Also, take it to a real repair shop. What people can't figure out what's wrong and they are suppose to get paid for it. Sad.
这个答案有帮助吗?
得分 0
添加一条评论
I think Im going to trash it and just go back to my old flip sony phone.
It's a rock, fits in my pocket and I will save about 50 bucks a month.
Thanks for answering.
Dave
这个答案有帮助吗?
得分 0
1条评论:
No problem.
If you are really going to trash it you should give it to me.
完成的
添加一条评论
添加你的答案
Angel Raldiris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 3,686
