跳转到主内容
Released in October 2003, the iBook G4 replaced the iBook G3 as Apple's portable consumer computer. The iBook G4 was sold in 12" and 14" models and updated for the last time in 2005.
530 个问题 查看全部
问题已关闭
iBook shuts down then I have to reset the date and time
hi, my ibook shuts down after 10 minutes or so then when i do power back up i have to go and reset the time and date stamp. I bought a new charger and adapter, i reset the PRAM and all that good stuff and it continues to do the same thing. After reading a lot of similar problems I think i might have to replace the dc-in board? Just want some confirmation before i buy the dc.
thank you,
edie
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
1- Have you tried running this iBook without the battery ?
A defctive battery cell could possibly cause DC overload.
2- Possibility of a defective fan inside the iBook.
3- If you open it, also consider changing the PRAM battery to solve the date and time isue.
Update
4- Have you had a chance to try an other power adapter ? If you try an other one, make sure it has the same power (or higher) as the original.
5- Most computers are equipped with an inside cooling fan to prevent overheating (yours definitely has one); is your fan running after a few minutes ? If not, perhaps it is jammed or it has a heat sensor issue. This can also shut down your computer after a few minutes.
6- As for the PRAM battery, sorry for misleading you earlier, I just read in an other article that iBooks G3 and G4 don't have PRAM battery, so if your battery is dead, you will loose parameters like date and time.
这个答案有帮助吗?
得分 1
2条评论:
1. yes, i have and it still shuts down
2. as for the fan, i didn't check, when i check the fan, what is it that i am looking for? (sorry, this is my 1st mac)
3.by checking the pram battery, is there a tutorial you can recommend?
also, i forgot to mention that the dc-in board my bf mentioned that it looked like it might have burned? But i didn't see anything like that. By the way thank u so much for your help!
完成的
yes, i actually bought a new adapter with the same voltage as the original. I also checked on the fan, as it was powering on, i heard it go off not even 1 minute and it shut down. but i opened it and it look fine, nothing seem to be blocking and it looked burn free. Any other suggestions? Is it going to be me replacing the dc in- board?
完成的
添加一条评论
Download iStat Pro (google it), it's a very handy dashboard widget to observe fan speeds, themps and other things. Great for troubleshooting.
Have also a look at the System Profiler (Apple -> About your Mac -> More Info) and look under the power section for the state of your battery and charging. You can also download "Coconut Battery" (again, google it) for more comprehensive information about the state of your battery.
这个答案有帮助吗?
得分 1
1条评论:
I would love to and I will once my ibook stays on for a longer .time Thank you!
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 3
总计 1,078
