跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2264 个问题 查看全部
iPhone freezes after a while
Hello,
Recently I replaced the lcd + digitizer on an iPhone 7. After a test everything works, but after a while the iPhone locks up while using: the screen freezes (still showing everything) but the digitizer doesn't seem to be reacting.
The only thing that works is a soft reset ( power down + wake). After reboot the iPhone works again.
But the problem returns so a soft reset is needed again.
First time I'm having this issue. Is this just a faulty screen?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
it does this with the original screen also? if not then you have a replacement screen issue
完成的
添加一条评论
2个答案
Hello! Does the device seem hot?
这个答案有帮助吗?
得分 0
添加一条评论
Classic symptom of a faulty screen, try another one!
Best of luck with the repair :)
这个答案有帮助吗?
得分 0
1条评论:
Thanks for your reply. The soft reset was needed 3 times day after repair. But now we're 1 day further and it only happened once. Could it be related to some static electricity or something? If it keeps happening I will replace the screen of course, but we're waiting an extra day to see if it resolves by itself or not.
完成的
添加一条评论
添加你的答案
FD Tech 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 124
