跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
iPhone 7 home button clicking taps 3-4 times at once
Hello guys, I run a repair shop, where I several times hav replaces cracks iPhone 7 screen some of them work with the original home button and other not, they finger print still working but not the button some times, I am sitting right next are rose color iPhone which have this issue, I have run a DFU on it with iOS 10.3.3, and now the button is working but it taps more than 5-6 time at once push, what is the problem, I have tried 3-4 screen, stil same problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Loosen the home button bracket screws; they are probably too tight. Loosen them very slowly until it works correctly.
这个答案有帮助吗?
得分 4
添加一条评论
the cable was damaged on removal, they need heat to loosen the glue, the u10 chip is soon delicate be careful
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abiran 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 7,806
