跳转到主内容
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
1364 个问题 查看全部
Both Cameras rear and front also flashlight not work
Hi guys,
i have iphone7 plus :
please help me to fix it with hardware or software ,
restore and rest all not work
thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
When you speak to people on the phone, do you have any issues hearing them or is it just the cameras and the flash/ light just not working?
完成的
no ,
just my both cameras and flashlight not work ,
完成的
@proactivelazy Hey Benjamin I’m also experiencing this issue both cameras are black the flash doesn’t work and FaceTime doesn’t allow calls. When talking on the phone the call volume is so low I can only really talk on speakerphone. Do you have any idea what the issue might be?
完成的
添加一条评论
6个答案
最有帮助的答案
I've seen this behavior in an iPhone 6S before, it turned out the rear facing camera was internally damaged, causing all the camera's to stop working.
I suggest you open up the phone and disconnect both camera's, see if the flashlight comes back to life. Then you can plug in the camera's one at a time and see if one of them works to isolate the faulty camera.
The teardown guide can help you open up the device. Good luck!
iPhone 7拆解
这个答案有帮助吗?
得分 2
添加一条评论
Hi
actually i opened the iPhone and disconnect both cameras , and also disconnect front camera and flash light , but still not work , i think it's hard ware issues ,
thanks
这个答案有帮助吗?
得分 0
添加一条评论
just black screen on both cameras,
这个答案有帮助吗?
得分 0
添加一条评论
Would be a little bit to strange if ALL cameras including the flash are not working anymore - at the end these are four different connectors.
Did you tried to disconnect the back cameras ONLY and leave the Facecam connected? Does it work then? Or the other row: Disconnect the Front-Camera and connect the back ones? And finally ONLY remove the flashlight-flex and connect all cameras?
这个答案有帮助吗?
得分 0
1条评论:
Hi,
yes first i disconnect the rear cameras only and checked it flash light and front camera not work,
and after that i disconnected the flash light still front camera not work , and after that disconnect the front camera but no chance for all cameras and flash light ,
and when i open the camera app the iPhone warming
thanks
完成的
添加一条评论
Hi please if you find a solution that tell me I have the same problem and can not find a solution
这个答案有帮助吗?
得分 0
2条评论:
Hi,
problem fixed with replace the rear cameras
完成的
Thank you I will replace the camera
完成的
添加一条评论
Yes front and rear camera and flashlight not working
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Power Max 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 5
总计 3,663
