Both Cameras rear and front also flashlight not work
Hi guys,
i have iphone7 plus :
please help me to fix it with hardware or software ,
restore and rest all not work
thanks
I've seen this behavior in an iPhone 6S before, it turned out the rear facing camera was internally damaged, causing all the camera's to stop working.
I suggest you open up the phone and disconnect both camera's, see if the flashlight comes back to life. Then you can plug in the camera's one at a time and see if one of them works to isolate the faulty camera.
The teardown guide can help you open up the device. Good luck!
这个答案有帮助吗?
Hi
actually i opened the iPhone and disconnect both cameras , and also disconnect front camera and flash light , but still not work , i think it's hard ware issues ,
thanks
这个答案有帮助吗?
Would be a little bit to strange if ALL cameras including the flash are not working anymore - at the end these are four different connectors.
Did you tried to disconnect the back cameras ONLY and leave the Facecam connected? Does it work then? Or the other row: Disconnect the Front-Camera and connect the back ones? And finally ONLY remove the flashlight-flex and connect all cameras?
这个答案有帮助吗?
Hi,
yes first i disconnect the rear cameras only and checked it flash light and front camera not work,
and after that i disconnected the flash light still front camera not work , and after that disconnect the front camera but no chance for all cameras and flash light ,
and when i open the camera app the iPhone warming
thanks
Hi please if you find a solution that tell me I have the same problem and can not find a solution
这个答案有帮助吗?
Hi,
problem fixed with replace the rear cameras
Thank you I will replace the camera
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,659
3条评论
When you speak to people on the phone, do you have any issues hearing them or is it just the cameras and the flash/ light just not working?
由 Benjamin 完成的
no ,
just my both cameras and flashlight not work ,
由 Power Max 完成的
@proactivelazy Hey Benjamin I’m also experiencing this issue both cameras are black the flash doesn’t work and FaceTime doesn’t allow calls. When talking on the phone the call volume is so low I can only really talk on speakerphone. Do you have any idea what the issue might be?
由 Joe Silent 完成的
