跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Sudden 'No battery available'
My Macbook Pro Retina 13" bought in July 2015 suddenly shows 'no battery available' even though it was working absolutely fine just the day before.
Its just a two year old machine...Is it possible for the battery to die overnight???
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
It could be the case of a dead battery but usually the batteries dont die from a day to another.
Try and do an SMC reset first of all, if that does not work try to disconnect and reconnect the battery here you have a guide on how to do it (follow from start to Step 6).
If this does not work you can buy a battery from iFixit and replace the old one
Replace a 6600 mAh battery compatible with MacBook Pro 13" Retina (Early 2015). 74.9 Watt Hours (Wh), 11.42 Volts (V).图片
产品
MacBook Pro 13" Retina (Early 2015) Battery
$79.99
这个答案有帮助吗?
得分 1
添加一条评论
Download and run Coconut Battery to get a much better idea of its condition.
http://www.coconut-flavour.com/coconutba...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Niyati Naudiyal 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,953
