跳转到主内容
加入维修社区 - 创建账户
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
Copper plate doesn't cover the other chip
Hello, while installing a new trackpad cable (thank you iFixit) in my MBP iris 13" early 2015, I noticed that the heatsink's copper plate does not cover the other chip (iris graphics perhaps?). Has anyone attempted using thermal pads, or some DIY cooling enhancement? I wonder this because the temperature seems to rise quite easily after a couple of lightroom usage, and the fans kick in really loud.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Just some poor design from Apple engineers. even if you will apply a thermal pad to that chip the heat will transfer in the best case to the back cover of the MBP which will already be hot so no cooling will be done. MBP fans do a good job in cooling/ exhausting the heat from inside of the machine and the motherboard has a good heat transfer properties.
Or try an external cooler to help out.
这个答案有帮助吗?
得分 0
添加一条评论
Look for an oily type of reside at the end of the heat sink where it is crimped. The heat sink is liquid fill and can leak and you lose its heat transfer properties.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ismael Pablo Ibarra Vrska 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 177
