跳转到主内容
Repair guides and support for your Sanyo TV.
358 个问题 查看全部
Why won't my tv come on?
Sanyo 40" LCD-40XR10F Tv doesn't come on but have power. Got a blank screen.
Was working fine last night but not this morning
Any ideas would be great and if it's a quick fix can I do it myself?
Any help would be greatly appreciated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
7条评论
mitchell Apperley any sign of life on your TV? Have you unplugged it yet and let it sit for a few minutes, disconnect everything from the inputs and then plug it back in? How do you know it has power?
完成的
Just have no picture but once I found the right channel I still had sound but still no screen
完成的
Can it be a lamp bulb?
完成的
Robert Robbins no bulbs there. Just a bunch of LED's
完成的
i got the same issue on my television.
black screen: like it has no power.
the sound works as i switch via remote to tv mode.
infrared sensor shows response with remote.
can someone help.
its an 43 inch led tv
model:Sanyo 109 cm (43 inches) XT-43S7100F Full HD LED IPS TV (Black)
完成的
显示更多的2条评论
添加一条评论
2个答案
已选择的解决方案
mitchell Apperley seems like nothing is ever really simple when it comes to repair. Anyhow, it could be an issue with the power board if none of the things I mentioned in my comment made a difference. You want to start with something like this
which is the troubleshooting flowchart for your set. Let us know if you have a multimeter etc. to start tearing down your TV. Sanyo is a little stingy, so there are no board layouts with the schematics. For that, we will rely on you and need you to post some good images of your boards with your question. Use this guide for that.
这个答案有帮助吗?
得分 2
添加一条评论
I held down menu and -volume, pressed power 1 time, to bring up menu. Then pressed volume to change settings. It came on. If I have to go to board and all that; I will get a new tv.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
mitchell Apperley 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 42
总计 13,761
