跳转到主内容
Why does OS X sometimes crash on startup and shutdown?
It doesn't happen all the time. Have run disc repair from install disc. One of the letters "m" has to be manipuated to work. Movie downloads sometimes freeze or crash on iTunes. Took it into Apple and tech looked at the data history and said it was probably a hard drive issue. But, I here no clicking in the drive. I have everything backed up. Just wanted to make sure there was something else I could try before I put in a new hard drive. Re-install O SX maybe? Thanks. Mike
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
If you have a good backup, such as Time Machine, I would zero out the drive. This writes zeros to every block, it's found in the format options. This will map out any bad blocks that may have developed. Then restore your data.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Michael McGuire 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 859
