跳转到主内容
加入维修社区 - 创建账户
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
iPhone 7 home button does not click
My iPhone 7 was submerged in water and now the home button is not working.
The Touch ID works perfectly, however, the home button does not click at all. The phone also still vibrates.
Do I need to replace the Taptic Engine? Or what do I need to replace?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I dropped my iphone 7 and the home button us not working , it does not click at all. The touch ID could not be used too. What should i do?
完成的
添加一条评论
5个答案
已选择的解决方案
Any device that came into contact with water, especially sea water, must be properly cleaned and decontaminated before anything else. Otherwise, you can have all kinds of latent issues down the road. However, with the iPhone 7, Home Button issues are essentially the one thing DIY & third party repair shops cannot address.
I would take a look at this previous question regarding iPhone 7 Home Buttons, particularly @rany 's answer, which is excellent iPhone 7 home button not working after screen replacement
In your case, you could have a logic board issue which may be repairable but if in the end your Home Button is defective, only Apple will be able to solve your problem.
这个答案有帮助吗?
得分 1
添加一条评论
I've not worked on the 7 yet, but have plenty of experience on 6 models. As for the "click"...it's just a mechanical mechanism that when pressed makes contact to close the circuit (I believe). If you gently remove the home button and set on flat surface, you should be able to press it and feel the click you mentioned...if not, clean with 90% or higher alcohol to help remove corrosion that may be preventing the click or movement to the contact points inside.
这个答案有帮助吗?
得分 1
2条评论:
Michael, the button on the iPhone 7 is all electronic, there is no physical actuator. You should read the thread I referenced in my answer. There are a few other threads as well.
完成的
Thank you... I was going by the 6 button where I could hear a click...I assumed the "click" he was referring to was same...but I will read up :)
完成的
添加一条评论
I bought a new motherboard for iPhone 7 Plus and now my button isn’t working? What do I do
这个答案有帮助吗?
得分 0
3条评论:
My iPhone7plus fell in the water..and now the home botton is not working.
完成的
Crazy Crai, the home button is encrypted to the original motherboard. It will never work again.
完成的
You need the original home button for that motherboard in order for it to work again
完成的
添加一条评论
My iPhone 7 turned all the way off at 100% like it died and now the home button don’t work.. anyone know why?
这个答案有帮助吗?
得分 0
添加一条评论
my iphone s 7 home button is not clicking but its very functional and the touch id works excellent… What can i do to fix it?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Adam Nevin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 27
总计 79,574
