跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Is the SSD soldered on?
Dear Everyone,
I am wondering whether or not I should buy the 13" MacBook Pro 2017, without the touchbar. One of my questions in this regard is whether the SSD in the MacBook is repairable after purchase. I tried to ask Apple, but they gave me different answers.
Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
The 13" with function keys does have a removable SSD. But! It's a custom part so it will only be available from Apple.
If you need to salvage something on the drive (if you killed your system some how) you would need to buy the exact same system as presently no one makes a case to hold the drive like what OWC does for the older models: OWC Envoy Pro USB 3.0 Enclosure For Apple Flash SSDs (June 2013-Current Mac Models)
As far as repairability or upgradability... Its about the same as the older 2015 model which is not good ;-{
Here's the IFIXIT teardown on the 2016 model which is exactly the same as the 2017 model: MacBook Pro 13" Function Keys Late 2016 Teardown
If you think the Touch Bar is better here's the IFIXIT teardown for it: MacBook Pro 13" Touch Bar Teardown which has a lower score of One!
MacBook Pro 13" Function Keys Late 2016图片
指南
带功能键版本的 MacBook Pro 13寸 2016年末款拆解
难度:
中等
MacBook Pro 13" Touch Bar Late 2016图片
指南
MacBook Pro 13 带 Touch Bar 版拆解
难度:
中等
这个答案有帮助吗?
得分 2
1条评论:
Dear Dan,
Thank you for your answer. So you can replace the SSD, if you e.g. find a used, identical MacBook Pro and use its SSD?
Kind regards,
Yousif
完成的
添加一条评论
添加你的答案
Yousif N. Al-Saif 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 6
总计 2,667
