跳转到主内容
5-Inch Portable Vehicle GPS with Lifetime Maps and Traffic (Discontinued by Manufacturer).
5 个问题 查看全部
Why does my 2557 shut off?
My Nuvi 2557 LMT frequently shuts off, particularly when traveling at low speed. The original power cable broke and I am using a generic power cable. Might there be a cable issue or has this Nuvi reached the next of it's serviceable life?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Is the port where the cable connects to the GPS loose at all It could be an issue of broken solder joints at the port and if you wiggle the wires around you get a connection . Inspect the port for how well it connects look closely inside the port forr lint or dirt and if you do need to clean the port use a toothpick are plastic pick . Dont use metal as it can break the port. Next check your cable as well could be a problem your new cable . How long will you GPS run without being plugged in , it may need a new battery. This guild will help with replacing the battery
Garmin Nuvi 2557LMT Battery Replacement
Hope this helps
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
MountWarnerVineyards 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 163
