跳转到主内容
Garmin Nuvi 2557LMT Battery Replacement
你所需要的
  1. Garmin Nuvi 2557LMT Battery Replacement, Garmin Nuvi 2557LMT Disassembly: 步骤 1 中的图像 1,1
    • Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
  2. Garmin Nuvi 2557LMT Battery Replacement: 步骤 2 中的图像 1,1
    • Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
  3. Garmin Nuvi 2557LMT Battery Replacement: 步骤 3 中的图像 1,1
    • There is a visible separation between the front and the back of the device.
    • Using a plastic opening tool, pry open the device along this separation.
    • Trying to open the device on the opposite side will rip the motherboard-display connector.
  4. Garmin Nuvi 2557LMT Battery Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 2557LMT Battery Replacement: 步骤 4 中的图像 2,2
    • Carefully pull apart the device by opening it up on the opposite side of the nameplate.
  5. Garmin Nuvi 2557LMT Battery Replacement, Battery: 步骤 5 中的图像 1,1
    • Using a plastic opening tool pry the battery away from the device.
    • The battery might be glued, so it might require a little bit of force to get it out.
  6. Garmin Nuvi 2557LMT Battery Replacement: 步骤 6 中的图像 1,1
    • Pull the battery-motherboard connector away from the motherboard.
结论
2等其他人完成本指南。
2条评论
On my Nuvi 2557, the silver name bezel is part of the front cover - it does not separate. I just split the case as shown.
The battery connector pulls out perpendicular to the pc board, and you re-insert it by aligning and pressing down against the board.
john horn - 回复
Would this apply to the Nuvi 2555LMT?
Bill Hines - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 1,219
