Why is my HDMI output not working?
My PS3 slim was running as if it was superior to PS4 (that was a hyperbole). Once suddenly the HDMI output stopped working after 2 months of not playing. Then, I changed to an SD for some time and then got a new HDMI cable. It worked.
After almost a year of well working, Suddenly the HDMI output stopped working when I was playing Minecraft. I tried using a new cable, but this time it didn't work.
I searched a lot of IFIXIT forums and all around google. Everyone said,"hold the power button till the second beep." A guy also said that you should handshake,i.e. reset the video setting for a million times around (a hyperbole). I did try all of these but the problem didn't get resolved. SD output's rendering is very poor on my TV that if I see 10 building in HDMI assassin's creed 1, I see only 3 in SD.
How do I fix it?
Should I consider visiting a Sony centre?
I have the same problem too!!! Except that I just woke up and tried to use the cord. My High Definition Multimedia Interface cord won't work! I even tried switching slots!!!
由 Gameplayer Jacob 完成的
My PS3 was dropped down now it's no longer showing on any output. No dry joints or cracks on the board. Please help
由 Emmanuel Chirwa 完成的
what do you mean dropped down? You're best idea is first start your own question not comment on someone else's
由 Zerocool278 完成的
My new PS3 (I replaced coz this problem wasnt fixed) Is showing the same problems. Please Help.
由 RishiNandhaVanchi 完成的
Am having the same problem but when connect using the avs it works just fine but the hdmi port doesn't display anything. Ps help
由 Jaston Gondwe 完成的
显示更多的2条评论
