跳转到主内容
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Power cutting out while in sleep and sometimes while in use
Mac Pro mid-2012
This machine has been cutting out periodically for about a year.
There are two problem areas. Firstly it cuts out when put to sleep. Secondly it cuts out randomly, perhaps after several weeks untroubled usage. It's very unpredictable in this respect. To get round the first problem I changed the energy save settings to let the screen sleep but not the computer [moving the pointer to 'never']. Obviously this doesn't solve the random cut-outs.
Apple had it for two weeks. They found nothing and suggested a software problem. I think that's wrong. It's baffling and resetting the PRAM/SMC hasn't worked [I did this myself and am certain Apple techs did the same as the first order of business] but since reading the advice dispensed to iMac owners with similar problems I now suspect something more serious.
Apple STUMPED - iMac shuts off randomly, daily to multiple times/hour
iMacs are not Mac Pros but is the weakness likely to be the same [logic board/power supply]? I'm guessing things will get worse over time so naturally I'm quite anxious to solve the problem. It's unfortunate I'm very much a non 'techie' type, and that these things are often too complicated to simplify for people like me, but with things as they are I'd just be terribly grateful for some advice. Thank you.
Jack
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Please explain what you mean by "cuts out".
完成的
Hello Mayer,
By 'cutting out' I mean switches off unexpectedly, randomly, with no warning.
完成的
This happened to me a couple years back- turns out my mac pro shipped with a graphics card that was later recalled. Took it to a repair place that swapped it out for free and the random crashes totally stopped! It still can’t sleep without crashing, but I don’t have to worry about losing my work in the middle of a project anymore.
完成的
添加一条评论
1个答案
已选择的解决方案
My experience with the 2009-2012 Mac Pros has show a problem with the power supply. I've had several that will restart on their own. As time goes by the frequency of these restarts accelerates. On every one of them, replacing the power supply solved the problem. The other main issue with these has been failing video cards, (my 2009 is on it's third).
There also appears to be a sleep issue with Sierra. I have noticed that in the last couple of months I now have to press the power button to wake up after my machine has slept. I believe this to be an issue with a Sierra update. It is not happening with El Capitan.
这个答案有帮助吗?
得分 4
11条评论:
I appreciate your replying Mayer. I'm not convinced it's a software problem that's for sure. Since I'm housebound now and another visit to Apple is out of the question I've decided to contact a local IT specialist about the problem [the only one I've found in a sea of Windows technicians willing to deal with Macs]. I'll see what he says about the likely bill for replacements and take it from there. My thanks once again for steering me in the right direction. I feel certain you're correct about 'probable cause'.
完成的
Gee, @mayer you're only on your third GPU card! ;-} Our last original Mac Pro (2012) has eaten seven! And is on its third power supply.
完成的
@danj I think the cards are object to restarts, like a light bulb, so I rarely shut down. Besides, this thing make a nice room heater in the winter. I have never seen the iMacs do this restart thing when the PSU fails. But it has happened on every MacPro with a PSU failure going back to the 2008 machines.
完成的
@mayer - I'm running El Capitan so maybe I'll stick with it in view of what you say. You're right about these things making %#*@ good room heaters though. I'll update the page once I've found the solution.
完成的
@mayer - We're on the same page here. Yes, the iMac issue is very different beast.
完成的
显示更多的6条评论
添加一条评论
添加你的答案
Jack 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 15
总计 517
