跳转到主内容
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
Keyboard and Trackpad not working (Power button working)
Hi,
Just bought an old 2011 15 inch Macbook Pro knowing keyboard and trackpad are not working.
The Power button is working, but i'm not able to make a PRAM or SMC Reset.
My Question: Why is both not working when there are separate connectors of keyboard and Trackpad? (Connector cable of keyboard seems used but then again the power button and the backlight is working)
Trackpad is not working at all.
What can I do?
Thanks!
Update (08/03/2017)
Thanks for the reply. Ok sounds bad, None of the keys is working ( i can normally use it with usb mouse and keyboard works completely fine), Battary is from 2015 (coconut battary) 160 cycles, not swollen. No screen anomalies, but a big bump on the outer aluminium body - so it definitely fell hard some time ago.
How could broken a hard drive/IR cable affect the keyboard/trackpad function?
Thanks
Update (08/08/2017)
Hi, Just replaced the Keyboard and it sadly it still wont be recognized - But i just saw the the chip above the Keyboard and Trackpad Connectors has one brown, corroded contact (from the back) - maybe that chip is broken... Do you have other ideas?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
FIXED my issue with the keyboard and trackpad not working. Same exact Started with the computer shutting down and not being responsive for a day. Then it turned into a couple of days in between uses. Both the keyboard and the trackpad were completely unresponsive EXCEPT for the power key. I tried resetting the SMC and PRAM which did nothing. Followed these steps after purchasing the full kit from iFixIt and BOOM!!! All systems go!!! Plus, now my battery is fresh! These instructions were great - made the process very manageable for someone with a very limited tech knowledgeable. The side-by-side pictures were a huge help - you NEVER see that kind of detail and clarity from pictures in instructions. THANK YOU for this!!!
完成的
添加一条评论
1个答案
已选择的解决方案
Possible liquid damage. Test all the keys individually. Open and check trackpad to logic board connection, see if you can tell if someone has been in it. Check for a swollen battery. Do you have any screen anomalies? This machine had a recall on the GPU. Know hard drive/IR cable issues.
UPDATE
Ok, your keyboard appears to have shorted out, probably due to liquid. Here's a video on how to replace it. Takes me about 2.25 hrs with an electric screwdriver (but I'm a pro so plan on 4 hours if you're a noob)
https://www.youtube.com/watch?v=lvqbrJ02...
Here's the part: http://www.ebay.com/itm/100-New-Original...
Here's the guide for removing the upper case: MacBook Pro 15" Unibody Late 2011 Upper Case Replacement
or you say (that's more than i wanted to get into, just get me to the damned part) well here it is:
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Upper Case
Replace an upper case, backlit keyboard, and battery level indicator assembly compatible with the Early 2011 to Mid 2012 15 inch MacBook Pro Unibody laptop.图片
产品
$59.99
这个答案有帮助吗?
得分 1
4条评论:
updated the question =)
完成的
Hard drive cable is just a known issue if you start getting beach balls, replace it with the 2012 model cable. Updated the answer. Get the keyboard working and then address the possibly shorted out trackpad.
完成的
Hi thanks for the awesome tips! will try to replace the keyboard and i'll let you know what works by then =)
完成的
Hi, Just replaced the Keyboard and it sadly it still wont be recognized - But i just saw the the chip above the Keyboard and Trackpad Connectors has one "brown" contact (from the back) - maybe that chip is broken... Do you have other ideas?
完成的
添加一条评论
添加你的答案
Phil Gr 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 6
总计 4,294
