跳转到主内容
This LG Android device was released in October of 2015. The model number of the device used to create these guides is LG-VS990.
What is the best (easy) way to fix the Bootloop issue?
My LG V10 got the dreaded bootloop issue. It would no longer power on or charge. There are many fixes on the internet but they are quite intricate and complex. Is there a straightforward method?
Update (08/03/2017)
How exactly do you apply heat? I only have a blow dryer...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Take of the motherboard, apply heat around 100 degrees celcius and then apply some thermal paste on the black coloured chips and put it back... THIS IS A TEMPORARY SOLUTION. My suggestion is go to lgmobilerepair.com and send ur phone to the lg facility.. they'll repair it fror free no matter the warranty.
完成的
I suggest that you avoid doing this, as there is greater risk involved in reflowing PCBs on your own. You could make it even worse. Send it in as the previous person suggested.
完成的
添加一条评论
1个答案
The only method I've had luck with is to disassemble and reflow the problematic chip with heat. All the other tricks/tips you see are only temporary (or momentary) fixes.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alina Dahl 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 2,275
