跳转到主内容
加入维修社区 - 创建账户
发布于2017年7月28日,New Nintendo 2DS XL 是 2DS 掌机的技术改进型重塑机型。它是 Nintendo DS 系列的第九款,也是最后一款重新设计的产品。该主机比原始的 2DS 机型大得多,并增加了“New 3DS”系列升级版系统的所有功能,减去了在顶部屏幕上以立体 3D 效果玩游戏的功能。
How do I replace the Bottom screen and Top Screen
Hi, someone through my bag, and it dropped onto a tree stump. Both of the screens are damaged on my 2ds xl, the top one has lines going through it and the bottom touch screen is fully smashed, and won't work at all. Everything else works fine, the controls, speakers and all that but I just want to know weather it would be better to buy a new one, or to repair the one I have already.
Thanks and Cheers of all of you who have an answer to this problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
4条评论
I have a problem like this,the bottom screen of my 2ds Xl is not functioning due to a dent and scratches. I'm only a kid so no money,how do I fix the bottom screen?
由完成的
You’re gonna have to buy a replacement screen. Luckily, not too much. Probably $15-$30.
由完成的
My bottom screen works fine but the top screen feel off do you no how to fix it?
由完成的
So exactly the same thin as Liam but the top screen also I lost one of the connectors so I can not reattach the top screen do you know if I can get a replacement?
由完成的
添加一条评论
3个答案
已选择的解决方案
Hi!
While you can replace the bottom screen, the top one is, as @johnwp mentioned glued to the entire front panel.
You could follow this guide if you wish to fix your console yourself, you will only need a good source for the bottom LCD & digitizer and for the upper front panel. You could try AliExpress or eBay I guess.
这个答案有帮助吗?
得分 3
1条评论:
Where would you find a replacement for the top screen? eBay has none for sale.
Thanks
JB
由完成的
添加一条评论
The top LCD is NOT glued to the entire top glass. There is adhesive around the paremeter of the LCD holding it to the glass. If you haven't actually taken it apart, please do not give people the wrong information.
这个答案有帮助吗?
得分 3
添加一条评论
I don't think the top screen can be easily replaced. The top screen is a whole unit. There is liquid between the plastic and LCD. If you take the LCD away from the plastic piece it will only further damage it. As far as I know the only course of action is to send it in to Nintendo. Can anyone verify this?
这个答案有帮助吗?
得分 0
4条评论:
Oh, my brother smashed my top screen while I was sleeping, I have CFW, can I send
it to Nintendo even though it is hacked, and how much will it cost?
由完成的
If you can blindly navigate GodMode9, than you can uninstall CFW easily. It will cost $50 to send it to Nintendo, not including shipping.
由完成的
Weird seeing SirNapkin here, also, I bought a new screen for $60
由完成的
There is no liquid in between the plastic and the LCD, you cannot easily remove the LCD from the chasis without damaging it. But you only want to remove it when its damaged anyway. Can it be replaced, !&&* yeah it can
由完成的
添加一条评论
添加你的答案
Recco waite 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 35
总计 7,476
