跳转到主内容
加入维修社区 - 创建账户
Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
Graphics card replacement options
Hello, I just got a mid 2010 27" i7 iMac, and it has graphics failure, I'm pretty sure. It has artifacts on the screen, which are odd colored pixels randomly dotted around, and will occasionally log me out or restart. What are my replacement options? Will a graphics card from any unibody iMac work? The iMac currently has a Radeon HD 5750 with 1GB of ram. I'm fine with a downgrade, as long as the card can still power the large display. Replacement 5750's look pretty expensive, so I'm trying to see if there is a lower cost card I can use instead.
If you zoom in on the picture you can see what I'm talking about.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Hi Da, I dont think you will be able to fit the macbook pro graphics card in there because in my past experiences laptops dont usually use pci x 16 plugs. What i would do is find a new card for imacs and replace it. Good Luck!!
Update (07/26/2017)
da stumer oh then you should be fine using that card
这个答案有帮助吗?
得分 0
3条评论:
Not sure where you're getting MacBook Pro from, I was asking about unibody iMacs late 2009 through 2011
完成的
So should be fine using a card from any unibody iMac?
完成的
yes but the computer may not recognize the card and want to go into recovery which is ok there should be an option to keep all of your information
完成的
添加一条评论
Because architecture changes between the 2010 and 2011 the radeon HD 5750 with 1GB is going to be your best bet. Without having that level of Video support you will find your OS lagging substantially using Mac OS Sierra which already makes use of the video card processing capabilities. If you downgrade video cards expect that you may find Sierra not performing as smoothly. You may want to do a good blowout of your system.
One question do the pixels that are out of sync remain the same ones? Do they change between boots? If they are the same ones, then the pixels have frozen (often occurs from damage to the display, age or a combo of the 2) and a new video card will not alter this as the frozen pixel would be a physical characteric of the LCD screen.
If you have more substantial artifacts (sections rather than just pixels that are frozen) and happens with more than just one program. (I have found that more than one program will have artifacts until they are updated and then the artifacts go away because a software bug was the source of the issue)
Finally, and it is worth repeating that this iMac is susceptible to overheating in the area of the video card location. If you are getting artifacts suddenly, place your left hand of the back top left of your iMac display (just under the vent slit) and is this area extremely hot uncomfortable to keep your hand in place for an extended period. If so, this is a symptom that the fan is: A) Failing not properly exhausting heat from your video card, B) obstructed with debris (dust, hair, etc accumulates and should be properly blown out by someone able to disassemble and dislodge the built of debris. C) Software that is running is caught in a kernel panic resulting in overtaxing the video card resulting in the issue. D) Finally video card failure (often driven by A, B, and/or C) I actually spent $35 on a water cooling kit that I attached to the outside of my iMac aluminum case with the heat sink attachments place at the points on the imac where the heat generation occurs, Video card, CPU, HDD (this was my latest upgrade to my iMac who like yours is EMC 2390) Currently my mid 2010 houses quad core i-7 24GB RAM Dual SSD 240GB and 750 GB HDD (ODD Removed) External water cooling unit 2nd display at 1920x 1080p and primary at 2560 x 1440 and operating W10 in Virtual Machine. Like you I had a wave of random rebooting and artifacts which were tracked down to a mix of misbehaving software (kernel panic) and overheating of the video card (dirt and overtaxing of the system without robust heat management. Once those issues were resolved I haven't had issues after Sierra. (Not upgrading to High Sierra anytime soon, due to stability concerns)
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the reply! I ended up sending the card out for repair, and it still hasn't been fixed, but it looks like the vram failed. I would get the artifacts as soon as the computer turned on, so it wasn't a heat or display issue. I was able to do target display mode successfully once.
完成的
Hi, i have the same iMac and issue just like you. I've replaced the gpu with a used/refurbished one and it is beginning to fail. :-(
What did u do in the end? Did u fix it? Did u get a new one?
完成的
添加一条评论
添加你的答案
da stumer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 48
总计 2,033
