跳转到主内容
加入维修社区 - 创建账户
Apple Wireless Keyboard 的维修指南与支持。无线连接并操控你的 Apple 电脑。
Keyboard will not turn on, no green led lights up, no sign of damage
Hi, I have an outwardly perfect Mac wireless keyboard. However, I cannot get it to turn on (let alone pair with anything).
The on/off button moves normally, and there are no visible dents. I've changed the batteries to fresh ones, and I've even tried putting a bit of aluminum foil between the last battery and the end cap that secures the batteries in their compartment, just in case the spring was damaged and the batteries were not connecting properly.
I'm not aware of any spillages on the keyboard. I can only presume that there is something going wrong with the power management unit, or the on/off switch. Any suggestions ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
Apple Wireless Keyboard 逻辑板更换
You could try removing the board to see if you find anything damaged or broken.
If the terminals are corroded, that could be your issue.
I would suggest doing that and if you can, hook it back up with it out of the case and use something to short out the pins where the power button connect to see if the button broke, which is possible.
Any other questions please feel free to ask.
这个答案有帮助吗?
得分 1
添加一条评论
I had the exact same thing a few years ago. Basically, it died and I bought a new one. Sorry I can't be any more help.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Salisbury Mason 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 7,892
