跳转到主内容
加入维修社区 - 创建账户
Apple Wireless Keyboard Logic Board Replacement
你所需要的
  1. Apple Wireless Keyboard Logic Board Replacement, Logic Board: 步骤 1 中的图像 1,2 Apple Wireless Keyboard Logic Board Replacement, Logic Board: 步骤 1 中的图像 2,2
    • Insert a metal spudger to open the plastic part under the Keyboard
  2. Apple Wireless Keyboard Logic Board Replacement: 步骤 2 中的图像 1,1
    • Remove the screw
  3. Apple Wireless Keyboard Logic Board Replacement: 步骤 3 中的图像 1,3 Apple Wireless Keyboard Logic Board Replacement: 步骤 3 中的图像 2,3 Apple Wireless Keyboard Logic Board Replacement: 步骤 3 中的图像 3,3
    • Pull the lock up and disconnect the connection cable
  4. Apple Wireless Keyboard Logic Board Replacement: 步骤 4 中的图像 1,1
    • Keeping the connection cable, push out the logic board's placement
  5. Apple Wireless Keyboard Logic Board Replacement: 步骤 5 中的图像 1,1
    • Unlock the latch of the logic board
  6. Apple Wireless Keyboard Logic Board Replacement: 步骤 6 中的图像 1,1
    • Remove the logic board from the placement
结论
20等其他人完成本指南。
Nicola
于11/14/13注册
638 声望
撰写一个指南
9指南评论
Hi, anyone know where its possible to buy this logic board? My bluetooth chip is apparently broken
steve - 回复 分享
Which model of keyboard is this, because my A1255 doesn't disassemble like this - the battery terminal is solidly restrained inside the tube by means of a metal expansion ring. Doesn't seem user repairable :(
gordon jackson - 回复 分享
My power button was stuck. The shell was dented. This was an easier way to access and remove the button so I was able to file the inside of the tube smooth so the button would move freely.
Tony - 回复 分享
I have disassembled my keyboard as shown above, but now I need a replacement Wireless Keyboard Logic Board. I have not been able to find one. Any suggestions?
Martin Rubio - 回复 分享
Very nice! in my case the flat cable was not properly connecting. I only found out when i opened the cap to the logic board and saw the cable sitting slanted in its connector. Put it back straight and now it works again. Cheers!!
mollymol - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 78
总计 50,475
