跳转到主内容
Model A1225 / Mid 2007 and Early 2008 / 2.4, 2.8, or 3.06 GHz Core 2 Duo processor
20 个问题 查看全部
Serial Number is Unavailable?
I have a Mid 2007 iMac with a serial number that is Unavailable. Ive tried to obtain it in multiple different locations, everywhere it says that it is unavailable (terminal, about this mac, system report..) I've reinstalled twice and had no luck. I was reading that it is probable that the Logic Board had been replaced previously and the tech failed to reassign the serial, this is possible, as I am unaware of its past life. What can I do to get this thing a serial number? Im sure a customer wont want to buy it without..
Thanks in advance for the response!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Not sure it has that much value anymore. Here's the specs: iMac 24" 2.4 GHz Core 2 Duo (Mid 2007). OS X 10.11.x El Capitan is the last OS this system supports.
完成的
添加一条评论
2个答案
最有帮助的答案
It should be on the bottom of the stand.
这个答案有帮助吗?
得分 2
添加一条评论
You can take it to the apple store to get serialized, they should do it for free, give them a call first just to make sure.
这个答案有帮助吗?
得分 0
3条评论:
Sadly, this is such an old system Apple won't work on it any more.
完成的
That's what I thought.... Does any one know the legitimacy of using it without a serial?
完成的
Some things that need access to the S/N won't work like find my Mac as an example. If you are thinking of selling it the buyer might question it as being a clean system.
完成的
添加一条评论
添加你的答案
Taylor Struna 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 305
