Spanner broken and stuck on dremel
My dremel spanner is stuck inside the dremel. How do I remove the broken piece so i can replace it so it will grip the bit again when I tighten the collet nut on?
Britain and America Are Two Nations Divided by a Common Language
I though a spanner was a wrench. If this is a broken bit stuck in it, completely remove the collect to take any pressure off. Then usually a small thin flat head screwdriver can be inserted and the bit pushed out.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 9
总计 290
