跳转到主内容
The Mac Pro First Generation is an Intel Xeon-based workstation computer manufactured by Apple Inc. The first generation model includes the machines from 2006 through 2008.
Mac Pro wont just boot! + kernel panic
Hello,
Im trying too fix a mac pro 2008 3,1 3.0 8core. When its starts up it gives a kernel panic.
My first thoughts where that it had a bad hdd. I plugged it in another mac as a slave disk en got all sort of damage reports when using disk utility.
Internet recovery mode
Also when i tried internet recovery it wil not instal en fresh osx.
I got out the old hdd and plugged a new (old) one in. Which was completely erased and format journaled extended.
DVD
So ive tried to boot it with a dvd system disk os x lion (command +c) but its eventually gets a hickup and unfortunately shows a round sign with a stipe. Swap out the dvd drive with another one. same thing. new disk, same thing.
USB
next thing i've tried was to make it boot with a instal usb el captain. But when i startup with alt/option pressed it doesn't recognize the usb. and that sucks big time.
Ive cleaned the whole system which was pretty dusty and dirty.
I'm not a mac specialist and little bit out of options. I just cant get this sucker to run which i really want!!
Help/advise please!
In other comments i found a guy named Dan (@danj) and hope you can help me out.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Do you have the original system installation DVD for this machine?
完成的
No i wish. I bought my mac at an E-Waste business down the street from my house i forgot to ask them for the cd's. shortly affter the business closed down.
on the topic of kernel panic try disabling sip
Follow these steps to disable SIP:
Restart your Mac.
Before OS X starts up, hold down Command-R and keep it held down until you see an Apple icon and a progress bar. Release. This boots you into Recovery.
From the Utilities menu, select Terminal.
At the prompt type exactly the following and then press Return: csrutil disable
Terminal should display a message that SIP was disabled.
From the  menu, select Restart.
also try disabling kexts.
完成的
添加一条评论
1个答案
最有帮助的答案
did you flash anything to you mp 3,1? are you able to get in recovery mode hold the alt.
System Software Overview:
System Version: macOS 10.13 (17A330h)
Kernel Version: Darwin 17.0.0
Boot Volume: macos high
这个答案有帮助吗?
得分 1
1条评论:
Nice insight on the possible flash!
完成的
添加一条评论
添加你的答案
Vincent Limburg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 322
