Bypass firmware lock on Mid 2011 iMac
I was wondering if simply replacing the HDD will bypass the lock? I tried the ram trick with no luck. I have 3 machines that all have this issue and need to find a way to bypass the lock. Thanks!
Update: I swapped HDD's, and had no luck, still has firmware lock.
4条评论
Would you post a photo of what kind of lock it is as there are different ones.
由 mayer 完成的
They boot and ask for the name and password, but when i try to change the ram to different sizes and reset the PRAM it goes to the standard firmware lock screen. [image|1162418][image|1162419]
由 Taylor Struna 完成的
Keep the original HDDs with their respective computers! From what I understand, if you mount the drive externally on another computer, there is a file somewhere that contains the password. I don't recall exactly where it is, but I saw it somewhere online before.
由 da stumer 完成的
Taylor here's how how to get those images to post: Adding images to an existing answer
由 mayer 完成的
