跳转到主内容
2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
(CPU)s failed to load
Hello,
My Mac fails to load OS-X just gets stuck at the apple logo, after a lot of off/on cycles it will maybe start OS-X.
Some times during startup it will show a error log on the apple logo saying (CPU)s failed to load.
Please Help, thank you in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
I haven't seen this error before and I don't find anything on it anywhere are you sure the error is: (CPU)s failed to load ? Thats a very strange error call.
I would recommend seeing if you can find a friend with a Mac that you can connect to yours using Target Disk Mode to first backup anything important and also run Disk Utilities to see if your systems drive is healthy. Is this the original drive or a replacement? That maybe a factor here as well.
It maybe your logic board has a problem which would mean you need to replace it, if the problem is not the SSD drive.
这个答案有帮助吗?
得分 3
14条评论:
I've never seen that error either. Possible virus, do you have a Windows partition on this machine?
完成的
Went to the apple store, he was saying that most likely the logic board needs replacement. Hope of coarse its something simple
完成的
Yes I head a boot-camp partition on it but after i wiped the system clean got rid of the partition and reinstalled to factory, still the same issue. Ran Health aid and pressed "D" on start up to get to diagnose screen. Every time i did that there where never any issues.
完成的
You really need to try to access from an external source like Dan mentioned or an external USB drive. I get really sick of hearing other techs or computer stores telling people they need a new logic board. 90% of the time, the logic board is not the issue. But your message has never been seen by two very experienced pros (I've been at it for 36 years and never seen this message Try starting in Safe Mode by holding down the Shift key on boot and tell (better to take picture) us your results.
完成的
Tried different methods like holding down shift, tried to reset the SVMC(i think that's what its called) hold down option, command, P & R. Tried to reset else not sure what its called when the screen is not turning on after holding down 4 buttons for 10 seconds. Another one where you have to hear the chime 2x to enter some kind of mode. Also the middle part right in front of the keyboard is getting pretty hot, didn't know that the MBP starts boot-camp in default after my battery ran out of juice and went into windows 7 sleep mode, was sitting like that for a long time till i noticed and the mac was very hot, just wondering if i fried it. The pre-owner told me that this model doesn't have a cooling fan. Sorry for the terrible description but i'm 2 months in to the mac world and still learning all the tricks.
完成的
显示更多的9条评论
添加一条评论
添加你的答案
; l; 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 228
