跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
590 个问题 查看全部
Does anyone know what this kernel panic report means?
panic(cpu 3 caller 0xffffff7f8ce92bd5): "GPU Panic: [<None>] 5 3 7f 0 0 0 0 3 : NVRM[0/1:0:0]: Read Error 0x00100c80: CFG 0xffffffff 0xffffffff 0xffffffff, BAR0 0xd2000000 0xffffff9125fd2000 0x0a5480a2, D0, P3/4\n"@/Library/Caches/com.apple.xbs/Sources/AppleGraphicsControl/AppleGraphicsControl-3.12.9/src/AppleMuxControl/kext/GPUPanic.cpp:127
Here's the full report: Panic Report
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you give us the exact model as that would help isolating what you'll need to do to fix this. Plug-in your systems S/N here: EveryMac - Lookup. Once you know paste the system URL here for us to see.
完成的
添加一条评论
1个答案
已选择的解决方案
It's the issue with the bad tantalum capacitor that needs to be replaced with a solid state one if I recall correctly.
Graphics not switching properly between the nvidia dedicated graphics and intel integrated graphics causing kernel panics.
There is a video on how to do this:
https://www.youtube.com/watch?v=DzcgT_fi...
Also good info on what capacitor it should be replaced with:
Logic Board Failure due to Nvidia Graphics processor GT330M
这个答案有帮助吗?
得分 4
2条评论:
@benjamen50 - You got it Ben!
I might add this is an easy repair for someone who has the correct tools and skills. This is on the edge of most DIY'ers.
完成的
To prove the issue is the capacitor you can force the system to use the Intergraded graphics using this tool: gfxCardStatus if the system is stable then you've proved it.
完成的
添加一条评论
添加你的答案
dollartripclub 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 4,627
