跳转到主内容
加入维修社区 - 创建账户
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
Why it won't charge anymore?
It won't charge anymore. I have tried other wires. My iPhone charges. So I know it's the charging port.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I would suspect that the iPod's battery is dead seeing as how this unit is probably 5 years old. iFixit doesn't sell the battery but a quick Google search should point you in the right direction. I would follow this guide for the replacement. Keep in mind that the battery is soldered in place so it will require some soldering skills to complete the repair.
这个答案有帮助吗?
得分 2
添加一条评论
I read somewhere to look inside the charging port to see if it's dirty. I poked in a toothpick, and a piece of lint came out. Problem solved!
这个答案有帮助吗?
得分 1
2条评论:
That's exactly what was the issue with mine! There was something in there. I put a toothpick in there and worked it out. Thanks for the tip!
完成的
I just fixed mine doing the same thing! There was a piece of lint or something in there!
完成的
添加一条评论
添加你的答案
Monica 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 56
总计 10,382
