跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Why is my Initial Time Machine backup taking forever
I purchased the ifixit battery replacement for my mid2012 mbp. Before attempting this project I decided to do a backup (I know, why have I waited 5 years to start backing things up, sorry). I connected a network hard drive (WD/myCloud) 4tb and proceeded on to my first backup. The MBP has a 500gb SDD with about 100gb free.
The Time machine has been running for three days now and it says Backing up 26gb of 28gb, those number are slowly increasing. so, it said backing up 15 gb of 18gb yesterday.
What's wrong? this is clearly not working, so before I pull the plug and start over, does anyone know what I am doing wrong?
Thanks in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Well, I started it over, disabled the wifi, plugged into the same hub as the drive, and this time it says "backing up X of 265gb". So I think this working, although it is saying 12 hours remaining and it has been running for 12 already.
As for the format, it was pre-formatted and it says it has built in functionality to support OSX time machine backups.
I'll report back in 12 hours :)
Thanks for the advice.
完成的
What I finally ended up doing was to simply go buy a USB drive and hook it up directly. took about 8 hours to back up the initial 250gb.
完成的
添加一条评论
1个答案
已选择的解决方案
Sounds like a wi-fi connection problem to me. Now the cart before the horse. You need to back it up before going after the connection problem. So I would start over and use a direct ethernet connection. Did you format the WD to GUID or leave it FAT? or MS DOS? Time Machine backup seem to work better on GUID drives.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Fred Anderson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 1,123
