跳转到主内容
Repair and disassembly guides for HP printers.
1090 个问题 查看全部
问题已关闭
Envelope printing has stopped working as it should
I have a HP Officejet Printer J4680. Printing an envelope w/address and return address used to work fine. Then, when shifting from one type of envelope to another it no longer printed as it should. It is now not possible to go back to the basic #10 envelope address printing. It just stays on the format for envelope C5. Will not change to any other type. Is this a problem with my printer, or MS Word?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Go online and see if you can download a new set of print drivers. It looks like they are available. Delete your old setup and after you update the drivers re-setup the printer. That normally does the trick.
Good luck
http://h10025.www1.hp.com/ewfrf/wc/softw...
这个答案有帮助吗?
得分 4
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 1,070
