跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2266 个问题 查看全部
Vertical and horizontal stripes after screen replacement, why?
I had my iPhone 7 repaired yesterday. The screen was replaced because I broke it. It was working fine up until today, every so often green and black vertical lines appear then the screen turns into as it was set to "inverted colours" and then slowly turns into a white screen. Locking and unlocking the screen instantly fixes ( which is why i think that it might be something with the software) the problem but it is quite annoying as it happens every 2 minutes. I tried soft reset but it didn't solve the problem. I will obviously bring it back asap, but I would like to have and idea of what the problem could be ?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Definitely a defective screen now...
Go back to the place where you get the replacement done and ask them to rectify it.
If you didnt drop it or whatever, then the screen replaced wasn't a good one for sure.
Have a good day.
这个答案有帮助吗?
得分 0
1条评论:
Can it be that it is not connected properly or it is sure that the screen itself is defective?
完成的
添加一条评论
添加你的答案
camilla h 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 182
