跳转到主内容
该机型使用非 Unibody 一体成型机身,使用 Core Duo 及 Core 2 Duo 处理器。
Latch won't open after installing new harddrive
I upgraded my harddrive and installed OS without a problem, but after putting the case back together, the latch won't open fully, meaning I need to use the spludger to gently pop it open. I had a similar problem when I had my RAM upgraded last year, but the guys at the shop where I had it done were able to fix it. I'd prefer to not have to go back there again.
Does anyone know how to fix this?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
thanks for your help guys.....not sure what the problem was but it worked itself out....I think it was just an alignment issue
完成的
添加一条评论
2个答案
已选择的解决方案
Most likely is that the top case was improperly aligned improperly. It's impossible for us to tell over the internet. I would examine how it's binding and reseat the top case.
这个答案有帮助吗?
得分 2
添加一条评论
Hi, it sounds like there may be a small screw lodged somewhere underneath or behind the push-button bar. I think you can remove that bar after you've removed the top cover. From there you can see if there is anything keeping that press bar from being fully depress.
这个答案有帮助吗?
得分 0
1条评论:
charles, I don't mean to be tacky but do you really think he's still having this problem after seven months?
完成的
添加一条评论
添加你的答案
stevehort 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,146
