跳转到主内容
加入维修社区 - 创建账户
The Samsung Galaxy Note 5 (called the Note5) is a phablet-style phone with stylus, manufactured by Samsung, released in August 2015.
bootlooped note 5 data pull
I found my note 5 caught in a boot loop after I woke up this morning. I've been doing everything to try and get it out but no luck. I am willing to reset my phone if I have my data though, so I was wondering if there is any software I could download which would let me pull data (such as pictures, videos, music etc) while the phone is stuck in a loop. I can power it off using recovery settings. Clearing the cache doesn't help. I'm not even sure if resetting would solve the looping issue but any info would be much appreciated, thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
You need to be able to flash a custom recovery then use the file system mtp mounting to computer then you can read the data. System and data partition should be mounted in system recovery.
You might even be able to just get the phone working again by reflash the firmware via Odin.
How to flash android firmware: http://updato.com/how-to/how-to-install-...
I usually use TWRP or clockworkmod recovery Odin flashable to do data recovery on firmware that refuses to boot without factory reset (and or firmware reflash).
这个答案有帮助吗?
得分 3
4条评论:
So I flashed new firmware onto it and it is still looping. Should I try flashing an older version of the firmware or something? What do you suggest?
完成的
Then you need to flash a custom recovery so that you can use MTP mode to backup contacts and photos while in a custom recovery.
https://twrp.me/devices/samsunggalaxynot...
完成的
I tried flashing TWRP and It keeps failing, I also get an error on my download screen(on the phone) saying the FAP lock is on? Thanks for your help!
完成的
Oh.. If you have FRP lock then you are literally out of luck for data recovery. I'm afraid you will have to do a wipe data / factory reset in recovery mode and lose all your data.
If you can still get into the recovery menu and do wipe-data then do it. Otherwise reflash firmware again and wipe data / factory reset in recovery mode.
完成的
添加一条评论
If you can get the phone into recovery mode, connect it to a PC with the adb tool.
The command 'adb pull <file>' can grab <files> from the phone.
这个答案有帮助吗?
得分 0
3条评论:
Could you give me an example of how I could do this to pull music for example and which tool would be the easiest to use? Also, I know I had developer tools enabled on my phone but I'm not sure if USB debugging was enabled. Thanks!
完成的
Here is a great article on that.
http://www.droidviews.com/push-pull-file...
完成的
I followed that tutorial but I kept on getting an error that it couldn't find the phone, I might be because the phone isn't in USB debugging mode but I have no way to change that.
完成的
添加一条评论
添加你的答案
Robel Efrem 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 19
总计 3,272
